Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I think the forum is a great idea, especially for those of us in consulting engineering. Keep up the good work!..."
Geography
bpcash (Mechanical)
16 Apr 09 9:18
Can anyone tell me why the vanes in rotary vane-type air motors are curved on the bottom? I've been tasked with re-evaluating the design of some of our motors.
hydtools (Mechanical)
16 Apr 09 16:13
To match the curved pocket in the rotor they fit into.  The pocket in the rotor is cut using a rotary cutter like a slitter saw.
Or they are parted off a round bar and then only three sides need to be straight and square.
Or both.
Or ask your original designers if they are still around.
Ted
bpcash (Mechanical)
16 Apr 09 16:16
Thanks. That could be what's confusing me. Our slots are square; I believe we are having them machined by EDM.
budt (Industrial)
16 Apr 09 21:03
The Vanes could be extruded duble width and then machined by sawing or milling into separate vanes. That would allow for the end that rides the cam ring to have sharp edges for sealing or the rounded end for line contact.
Bud Trinkel, Fluid Power Consultant
HYDRA-PNEU CONSULTING
bpcash (Mechanical)
20 Apr 09 13:45
Another vane design I have come across has chamfered ends on the bottom instead of a curved profile. I would think this sort of feature would serve some function.
automatic2 (Industrial)
25 Apr 09 19:50
vanes may be activated by inlet air pressure to extend them against the housing. A chamfered/rounded profile may be intended to allow better flow from the pressurizing port.
Close Box
Join Eng-Tips® Today!
Join Us             Close
