Branch connection
Branch connection
Branch connection
We are having a debate on if we should use Weldolets or regular pipe section welded to make branch connections.
I am browsing the web for any comparison.
Application is for light crude oil @ 350 GPM with 95 psi.
The reason for this debate is mainly if we can find a fitting where a instrumentation of 2" NPT connection can be fit on a 6" pipe. If we can't find the fitting then we have to make one and that is when the discussion started for using weldolets.
RE: Branch connection
Thread-o-let should be the easiest instead of making a part.
thanks
I've used both - and prefer thread-o-lets when possible.   (When allowed that is - some app's won't let me use threaded pipes.)
Tees?  Sure.
Never a pipe-stub-into-a-pipe.
