Seismic for Liq Containing Tank - Need example
Hey all - I have developed a spreadsheet to come up with all the design values in ACI 350.3-06 but having never used this reference before, I don't know if everything is working as it should. Does anyone have a design worked out (using ACI 350.3-06) that you would be willing to share with me? What I'd like to do is input the design parameters in the spreadsheet and see if it is producing all the correct values.
Thanks!
Thanks!
RE: Seismic for Liq Containing Tank - Need example
