Surface Delete in NX6
Hi NX6 Users,
How to delete a surface(s) in a 3D part w/o using synchronous tech.?
Thanks - Maxxforce23
RE: Surface Delete in NX6
There's no reason at all, I have try the regular way and using synchronous but it delete the whole feature every time rather than just a single surface that I want. I have used IDEAS for the past 15 yrs and it very easy to delete a surface(s) and I tried it in NX6 and have a problem doing so. I know there's an easy way but can't figured it out.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
I tried to delete one face of a solid body. Thanks!
Maxxforce23
Best Regards
Hudson
www.jamb.com.au
I will try it out and let you know later...
Maxxforce23
If so, try going to...
Insert -> Combine Bodies -> Unsew...
...and selecting the face(s) you wish to 'delete'. After you hit OK, while it may not look like anything happened, the solid has been 'split' into two 'sheet bodies', so just hide the portion which you no longer need (but don't try to actually delete it since it's now actually a feature and not really a separate sheet body).
Anyway, give that a shot and she if that was what you were looking for.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
This is the exact answer that I'm looking for, I have try it in NX6 and it works great. Thanks to other users that have shared their opinions regarding to my question.
Maxxforce23
