Motor Load-Torque
Motor Load-Torque
Hi guys,
I have a 3 phase induction motor and have calculated the load (calculated to be 75%) and the full load torque by using the following:
(HP x 5252)/Full load RPM
Would it be fair to say that the actual torque required by the load can be calculated as follows:
Actual Torque=Full Load Torque/0.75.
Thanks.
Thanks.
RE: Motor Load-Torque
Bill
"Why not the best?"
Jimmy Carter
An induction motor speed does not change by a large fraction from no-load to full load and so can be considered roughly constant speed. So the output torque is roughly proportional to the output power. Assuming no speed changing device (belt, gearbox etc), the load input torque is roughly the same (neglecting tranmsission losses) and so would be proportional to your estimated load (not inversely proportional as your /0.75 suggests)
to
Bill
"Why not the best?"
Jimmy Carter
