Timed process?
Timed process?
Timed process?
I'm building a flight simulation in Simulink....and while flying..you can press a button in the joystick and send a command to perform a process that last 15 secods. I'm opening a valve that will realise some gas...Long story short...I don't want to wait 15 seconds and then have the output...I want to use the output...while the 15 sec discharge is ocuring.
I thought about a timer...but I don't know how to do it...or if there is something better to do.
Thanks a lot
