Dynamic Shock Anlysis
Hello All,
For a Dynamic Shock Analysis what do I put in as the profile? It is asking for a spectrum, but is it the Shock Response Spectrum (SRS) which is in G vs Hz or the Power Spectrum Density (PSD) which is in G^2/Hz vs Hz?
Thanks for your help in advance!
Tobalcane
"If you avoid failure, you also avoid success."
