SP3 Assy / Dwg Bug
SP3 Assy / Dwg Bug
1) When opening a small Assembly with 2 parts they load light weight as they should, I RMB on either part in the history tree and the "set to resolved" option is there as it should be. So far so good!
2) Now I open up the drawing that contains the 2 parts plus the assembly, then I go back to the Assembly model and there is nothing on the screen??? The assembly model has dissapeared. The assembly history tree still shows the 2 parts as light weight, but when I RMB on one of the parts the menu "set to resolved" is not there as it was a second ago!!
Any Ideas?
Tom
Any Ideas?
Tom
Tom Malinski
http://www.okayind.com/
Dell Prec T5400, dual Xeon 3.16,
4GB Ram, Nvidia Quadra FX 5600
SWorks Premium 2009 SP2.1 PDMWorks
RE: SP3 Assy / Dwg Bug
Why do you have such a small assy loading lightweight?
Have you tried re-installing the video card driver?
Tom Malinski
