Large Scale Plotter Load
The print room in our building was designed for basic office use and due to the number of plotters in the room it is often uncomfortably warm, especially in the summer months. We have decided to install a split unit but have run into a slight problem in selecting a unit for the job. Does anyone know the sensible heat load that a large scale printer would produce while printing? I've done a fair amount of research and even contacted a few manufacturers but have had no luck.
RE: Large Scale Plotter Load
That could be a starting point.
Whenever I needed heat gain information for a device I was alwasy able to find some number to go by by talking to a mnaufacturer's tech support. Call Hewlett Packard. Even if it is not the type of plotter you have, I'm sure with HP being as big as they are they can give you a design number for their plotters.
