dimension overide in draft (st)
I have a problem. When in draft mode, if i am adding a suffix or prefix, and the mouse cursor moves off of the dialog box for the suffix/prefix, solid edge then thinks you are overiding the dimension and whatever input is typed is now in the dimension overide
i have attached a screenshot
RE: dimension overide in draft (st)
anyways, i have another issue that is very similar. when i am extruding something the cursor must be over the extrude menu or dialog box whatever it is now. if it is not over it solid edge will not recognize a typed distance.
this must be some setting that i cant seem to find, it has been a thorn in my productivity for months.
In V20 the focus usually moves automatically to the input field, but not in ST.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
should be fixed now. Note however, that the heading 'Extent ..'
is active (yellow colour) otherwise the value field will
not get the interrupt (the keyed-in value that is)
dy
