Tabular note problem
Hi Everyone
NX 4.0.4.2
I want to export a tabular note as an excel spread sheet but I am running into an issue. First I make a tabular note next I import part file attributes into that note to populate the cells. next I edit the note with spread sheet and do a "save a copy" and save the spread sheet somewhere on my system, the problem I have is when I open the saved spread sheet all the attribute values show up as "0" not the value from the part file. The attribute titles all show up properly but not the values themselves. Any help with this would be appreciated. I know I can export it to a text file but that is not what I "need".
Smitty
www.changes-consulting.com
