Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Want to thank those people who have made this forum such a valuable place to visit each day..."
Geography
Flanged connections into clean Rooms? acceptable?
jcme7212 (Chemical)
14 Apr 09 18:44
Hello
Can someone help me if there is any regulation that does not permit to use flanged connections into clean rooms? It is clear that not to be used for product lines or clean utilities lines, but for general utilities as chilled water or industrial waste.
Best Regards.
quark (Mechanical)
15 Apr 09 0:06
I never came across any such regulation. Shoudn't be an issue.
HEC (Mechanical)
19 Apr 09 18:20
jcme7212,
I donot believe there is any regulation or law prohibiting the use of flange joints. However you do need to consider materials of construction in relation to;
 How clean is the cleanroom you are setting up
 Can they be cleaned and sanitised, exposed threads can be a problem
 Do the materials tend to shed particles as they age.
Mark Hutton
pleckner (Chemical)
4 May 09 19:29
You will find that using flanged pipes within the clean space will not meet the guidelines of cGMP. You cannot properly clean the small crevices between the gaskets and the flange face.
Close Box
Join Eng-Tips® Today!
Join Us             Close
