Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just want to say how much I value your site. I hope the good work keeps up there. It's really helped me..."
Geography
cdstan (Civil/Environmental)
14 Apr 09 15:14
Does anyone use STABL and how can I manipulate the program to deal with MSE walls?
bucknell06 (Civil/Environmental)
15 Apr 09 11:13
Assuming you want to look at global stability only, you can use failure surface limits to cause the failure to occur outside of reinforced zone.
jdonville (Geotechnical)
15 Apr 09 20:54
cdstan,
Assume the MSE mass as a rigid block for global stability. Use limits as stated above to block failure surfaces passing through the MSE mass, or assign high strength parameters to the MSE mass.
Jeff
moe333 (Geotechnical)
15 Apr 09 21:45
A potential failure surface for global stability can pass through one or more of the reinforcement layers.  You would need to use a program that can model the reinforcement layers if you want to do a thorough evaluation.  There are some out there that are pretty reasonably priced.
Close Box
Join Eng-Tips® Today!
Join Us             Close
