Crane Opening Detail in Reinforced Concrete Slab
Looking for typical detail for crane opening in reinforced concrete flat slab structure.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Crane Opening Detail in Reinforced Concrete Slab
CAP4000 is correct - no such thing as a "typical" crane opening. Certainly the edges of the opening have to be treated as a construction joint for the future fill-in slab. The size of the opening has to allow for the movement of the crane's tower structure. The surrounding floor has to be designed for the opening and be self-supporting until the fill-in can be done. The surrounding structure may also need to be designed for any bracing loads imposed by the crane's tower structure. If it's a climbing crane, all crane reactions will be imposed onto the structure - the structure must be designed for these reactions.
Perhaps the crane supplier/manufacturing can help you to evaluate.
What size is the opening and what type of slab is it (one-way, post tensioned, thickness, etc.)?
Are they bracing the crane to the slab?
Typically want to leave a key for future slab infill, then add reinforcing around the opening (and diagonal reinforcing at corners) to 'carry' the concrete around the opening.
Even if you find a 'typical' make sure you check it works for your application.
Den32: Mentioned it is flat slab.
I am proposing opening in middle strip area.
crane is not supposed to imply load to the structural slab.
One clarifying question comes to mind - is this an opening to permit the passage of material from level-to-level OR is this an opening for a tower crane's tower? If it is the latter, then depending upon the height involved, the crane's tower may need to be braced to the building.
Ralph
