Relay Info required
Relay Info required
Relay Info required
Hi
I am urgently looking for as much technical info as possible on the following diff relays please:
1) Toshiba TYPE IBTID
2) Siemens 7UT22/23 (7TD32/33) and 7UD20 (7TD43)
3) BBC DIX 109a/110a/111a
4) BBC IBX 164
I appreciate that all these relays are obsolete (so I've been told by the local representatives of the manufcaturers). Maybe someone has some info on them in some archive somewhere?
Any assistance is much appreciated.
Thanks.
Veritas
RE: Relay Info required
veritas,
It is difficult to find literature on old relays, it was my experience too.
A couple of times when I faced this problem, I put in my request in the manufacturer's website and received help. Hope it will work for you too.
Hi raghun
I have done what you suggested. Hopefully someone will have some good news.
Zogzog
A very useful website indeed but it did not have any of the relays I was looking for. But I will sure keep this website in my favourites.
Thanks both of you.
Regards.
Veritas
Hi Veritas.
About BBC relays. Your local ABB center must ask ABB Baden
LEC Support, data about those relays, for my pinion, in the ABB  Baden data base in the scan form. I try check for you, if this data free of charge.
About Siemens, try check too.
Good Luck.
Slava
Thanks slavag.
Second part
slavag
You're a real star! Thanks so much for all your help. It is truly appreciated.
Veritas
