Controlling multiple asymmetric chamfers (NX5)
Hi all,
In NX 5.0.4.1, sometimes when adding more than one asymmetric chamfer in the same feature, one or more of them will not be the correct direction, meaning the short side and the long side need to be swapped. However, the Reverse Direction toggle flips all the chamfers sides together. Is there a way to control these individually?
RE: Controlling multiple asymmetric chamfers (NX5)
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
John R. Baker, P.E.
Cypress, CA
Didier
It's good that you're thinking about this but there is a now a reverse vector in the command with a preview which helps control the output unless you select multiple unconnected edges. The thing is if you add extra keystrokes and you always have to use them even if you probably don't have need of them then that becomes counter intuitive, but if you just hit apply you stay in the dialog and simply pick the next edge. Okay so the tool isn't designed to do separate chamfers inside a single feature, but chances are it is easier to do one at a time if you stick within those limitations. Going outside the limitations makes for complexity and that could actually make things worse.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
