openclipboard failed ERROR message!
Does anyone have a fix for the following error message.
"openclipboard failed".
It occurs when trying to insert a part or assembly into another assembly.
I am running Win XP 64 on a Dell T-7400 workstation.
SolidWorks 2009 SP 3.0
Thanks in advance
Thanks in advance
RE: openclipboard failed ERROR message!
It looks like if you run a remote desktop application this errors appears. I am remoting into my laptop for email and other things and only using the Workstation for SW.
thanks
My suggestion would be to disable Remote Desktop to determine if that is causing the problem.
I log on to the SW portal using my e-mail address and a password established using our license code.
Specific steps are:
1. go to solidworks.com
2. select "login" at the top of the page
3. select "solid works customer portal
4. enter your user name and password
5. then select "knowledge base"
I found the search capability very good. unfortunately the searches turn up many problems but with few solutions
