Torus Formula
Torus Formula
Torus Formula
Does anybody used torus formula for calculating the tube wall thickness on bends. If so, where can I find the formula.
RE: Torus Formula
I used Torus Formula whenever the tube thickness after bending does not meet minimum thickness requirement by ASME formula and the AI's typically accept this method. It is quite complicated so a MathCad file was developed. I cannot share it because it is a company property but I believe you can find the calculation method from many places online.
RE: Torus Formula
Thanks you, could you please advise some web address.
RE: Torus Formula
Try Roark book/s
RE: Torus Formula
Thank you very much, I found this is useful.
RE: Torus Formula
try asme b31.1 par 102.4.5, parameter "I".
