Revit file transfer
Revit file transfer
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Revit file transfer
I think the best thing would be to find out what modeling kernel Revit uses and then try to use this format to transfer data. Many Autodesk products use a variation of the ACIS kernel, so if you transfer using an older version of ACIS you get a good result with say AutoCAD. However, Revit was an independent company that was bought out by AutoDesk, so they might be using a different kernel all together. Another option would be to go kernel neutral and use STEP, which as you may know is much better than say IGES.
good luck,
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://www.robrodriguezblog.com
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
Jeff Mirisola, CSWP, Certified DriveWorks AE
CAD Administrator, Ultimate Survival Technologies
My Blog
Good luck!~~
