Weight of Pneumatic Three-way Valve for Power Plant
What is the weight of Pneumatic Three-way Valve for Power Plant?
Some design data of the valve is following.PN=28.7MPa,t=270℃,DN=325mm.
Thanks in advance.
Thanks in advance.
RE: Weight of Pneumatic Three-way Valve for Power Plant
Is it really DN 325? DN 300 has an outside diameter of 323.8. DN 300 and 350 seem more standard.
What flange class?
What material? (Carbon steel, stainless steel, nickel, etc.)
What size diaphragm or piston actuator, manual, gear driven, etc.?
Cast, fabricated, forged, etc.?
