subcooling region heat transfer coefficient in steam condensers
Hi everybody
I try to find a suitable correlation for the heat transfer coefficient of the shell side in the subcooling region of a shell & tube steam condenser.
I have found a equation from free convection which is the following:
Nu=0.138Gr^0.36(Pr^0.175-0.55)
(Perry's paragraph 5.13 eq.5.33a)
But the above equation give shell side heat transfer coefficient as high as in the shell side of condensation region (were I make use of the thin film consensation approach). I think that it should be lower.
Does anybody knows a well-known & proven equation for the shell side heat transfer coefficient in subcooling region.
Thanks in advance.
Thanks in advance.
RE: subcooling region heat transfer coefficient in steam condensers
rmw
