ASME New Certificate Scope for the Parts
the following case:
We are the Head manufacturer, we want to apply for the ASME U stamp, we only need to apply for the U part, it means that we only need the ASME Certificate U part, How about the Demonstation Products for the joint review because we have no any design, NDE, we only do the head plate welding , then forming, how to apply for the ASME certificate for the demonstation products? Thank you for you help.
RE: ASME New Certificate Scope for the Parts
the purchaser is responsible for the required minimum thickness and the fabricator who applies the final u stamp to vessel is responsible for the design
U-11. Manufacturer of pressure vessel parts at the above location only
U-12. Manufacturer of pressure vessel parts at the above location and field sites controlled by the above location
U-13. Manufacturer of pressure vessel parts at field sites controlled by the above location
U-14. Manufacturer of pressure vessel parts (cast iron only) at the above location only
Hope this helps.
