The equipment for manufacture of a carbon fibre and a carbon fabric
Hello, prompt please manufacturers of the equipment (on release of a carbonaceous fibre and a fabric) or how they can be found?
I am sorry for illiteracy because I Russian)))
Thankful in advance. Vladimir.
RE: The equipment for manufacture of a carbon fibre and a carbon fabric
Strictly, to follow the Eng-Tips rules, you should click the Red Flag button in the middle at the bottom of you post. This lets you explain to the Eng-Tips moderators that you'd like your post to be removed because you're reposting elsewhere. (The 'rules' say you shouldn't 'double-post' - things can get muddled if the same question appears in more than one place.)
When you repost it might pay to try to add a little bit about what you want the material for - otherwise there are really too many answers. (Or perhaps you could say what sort of ply thickness and quantity you want.)
If what you want is simply suppliers of carbon tape and cloth then Google is your best bet. There are many, many distributors. (If you want a supplier in Russia you could try adding inurl:ru to your search - an English language question such as carbon fibre suppliers inurl:ru might work quite well.)
