Falk Rexnord Fluid coupling. HFN1480
Hi all,
I am solving a prob which involves a fluid coupling.
This is was i need to know about the fluid coupling.
How much time does the fluid coupling provide as a delay before it couples the load to the motor.
I know that it depends on the orifice size and also the angle of fluid fed into the chamber. But when i go through the manual they say 100% of the original, 250% of the original, 440% of the original. What does that original refer to.
Also is there a linear relationship with the motor speed and the liquid pumped into the working chamber.
hopefully someone can answer
gokul
Hopefully some
gokul
Hopefully some
RE: Falk Rexnord Fluid coupling. HFN1480
Ted
