Preload of Bolts and Nuts
I'm trying to do an FEA which involves an assembly of two steel plates which are bolted-onto each other. The preload due to tightening of the nut & bolt is applied in the form of tensile force or pressure on the contact areas (acting in opposite directions to each other) between the bolt & plate and the nut & plate.
I'm wondering if the above inputs are enough for my FEA, or do I have to also include the forces that each plate applies onto the other due to the tightening preload?
I have attached a drawing which illustrates my question. Basically Option-1 is where I include only the preload force between bolt & plate and nut & plate (the arrow marks indicate the forces applied on the faces of the components). Option-2 is where I also include the forces that one plate applies onto the other due to the tightening.
So which option should I go with for my FEA - Option-1 or Option-2?
RE: Preload of Bolts and Nuts
corus
