Standard for Washers for use on Exchanger Girth Flange Bolting.
Is anyone familiar with the appropriate ASME, ANSI or ASTM standard normally quoted for washers to be used with A320 B8M studs with A194 8M nuts on an exchanger girth flange. We don't normally use washers, but when we have with alloy steel, B7/L7's, studs/nuts, we've used ASTM F436M, but what about for use with stainless steel?
