Roof extension
Roof extension
Hi
I am new in this forum and I do not know where to put this question.
I am involved in design of a new triangular aluminium canopy roof extending with an angle to 3m in height and length from an existing building with concrete walls and roof. The pik edge of roof will be supported by a diagonal with angle in vertical and horizontal directions (it is not straight in any direction).
Any idea how to design the roof, post and connection this roof to existing structure?
Any reference book or paper?
RE: Roof extension
RE: Roof extension
The existing building is a concrete/brick bunker with concrete roof. It will be extended with glass cladding and aluminium roofs.
Your comments are greatful.
Apparently I can not attache more than one file. If you require more sketches then please let me know.
RE: Roof extension
For US applications, The Aluminum Association has a design manual (ADM 2000 and ADM 2005)to cover the aspects of aluminum design.
Be careful with welded connections. The allowable stresses are greatly affected by welding.
Other than differences in properties, aluminum design is similar steel design.
RE: Roof extension
You then just need to supprt a main member from this column and run trimmers along each side.
Very simple engineering, just analyse it for wind, snow, live and dead loads then check it by the aluminium code.
RE: Roof extension
Another file shows existing structure.
RE: Roof extension
You could run horizontal members (say with expansion bolts) to top of wall and attach to it.
You could also run a vertical member bolted to wall and attach to the top of it.
Use lots of bolts add your own safety factor to that of the mfg. and watch out for prying action.
Let us know what your final design is, it looks interesting.
We don't want the roof to fly off the Gents.
RE: Roof extension
do you have nay example or sketch showing how to make those connections?
Do not forget hat the roof has slope, then it needs something like hinge to enable it to move up and down.
what about horizontal movement along the wall?
This is another sketch I have.
RE: Roof extension
Did you see pictures of the skywalk at the Grand canyon? It is all back span.
Think along these lines.
RE: Roof extension
No, I have not seen it. Could you please send it to me.
What a bout the connection in top and bottom of the column supporting top of the roof??
I attache another sketch below.
My main problem is connecting the end of roof to existing structure while allowing it to move to sides, up and down because of wind load. Also a part of new side roof is connected to it according the sketches.
Any sketches to undersand it better?
RE: Roof extension
RE: Roof extension
