Hi Lok Reamers
Hi Lok Reamers
I'm trying to find a supplier of Hi Lok Reamers, so far no luck either in the US, England or Australia.
I've sent out a bunch of RFQ's and haven't even got any answers yet!!
I need to supply these to a couple of my engineers who are working on a job soon - can anybody advise me of a company that can supply this tooling?
I'd appreciate any help
Teresa
Teresa
RE: Hi Lok Reamers
There are no such things as a "Hi-Lok Reamers".
Any reputable reamer vendor can supply NAS897 reamers on demand.
Your engineers will have to review NAS897 and determine WHICH reamers are needed, based on the following minimum criteria:
1. reamer cutting diameter [take into account desired fastener "fit" in hole... interference or close-fit]
2. Cutter-flute style [helical or straight]
3. pilot diameter [if required]
4. pilot length [if required]
5. material type [HSS or Cobalt HSS]
NOTE: Reamers can effectively increase hole diameters 0.008--0.016" max in aluminum alloys per pass... or less in very hard alloys [CRES, Titanium, etc]. Any larger reaming increments may become "rough" or loose precision tolerances required for HL Instl. If holes have to be oversized beyond 0.017", I recommend adding intermediate reamers to "step-up" the holes.
NOTE: reamers can only produce a limited quantity of high quality holes before resharpening is required. Your engineers MUST help You estimate the quantity of each reamer required to accomplish the work, plus (1) or (2) for "aw-shit-I-dropped-it" [accidental damage] occurances.
NOTE: If reaming lots of holes in aluminum, or very hard materials, then Cobalt HSS may be a wise option [not the cheapest].
NOTE: Aerospace reamers are specified/made slightly different than industrial reamers. Differences are subtle, but important.
NOTE: The drill-motor and chuck are integral to a high quality reaming job. Insure that the drill-motor/chuck combinatiion is capable of solidly gripping/centering the largest bit [some reamer shanks are very large]; and that they are capable of spinning the [largest] reamer-bits "DEAD STEADY" [NO WOBBLE]... otherwise Your holes will be "junk" [way out of tolerance].
Regards, Wil Taylor
RE: Hi Lok Reamers
