soften neoprene?
soften neoprene?
I'm wondering if there is any effective way to soften neoprene? I have some neoprene with durometer of 95 and would like it to be in the 70s or even lower.
would the methods for rubber works just as well? such as petroleum oils or bleach.
RE: soften neoprene?
If cured Neoprene then you should be aware that this polymer has good to excellent resistance to most mineral and synthetic oils, greases and fuels. You are unlikely to make any difference to the hardness of your compound. With regard to the effects of bleach solutions - my information tells me the resistance of Neoprene to bleach is poor at best but, again, any changes in hardness are likely to be a surface effect only.
If uncured you could add about 40phr dioctylphthalate or dioctylsebacate to the formula. This change will reduce the cured hardness by about 20 points.
