Removing Lines? (Simple Question)
If you take a look at the image, it doesnt look realistic with the lines on it.. How do I remove them? I know about the merge option, but that seems to ruin my fillets. Is there a way to get rid of the lines?
RE: Removing Lines? (Simple Question)
If I understand what you're asking for, try going to System Options > Display/Selection > Part/Assembly tangent edge display > then click the "removed" radio button.
That should do it.
Redline 8... Thank worked perfectly!!!
Thanks.
