Looking for a Stainless Steel W8 x 67# Beam Supplier
I know this is a shot in the dark, but does anybody know of a reputable supplier of non-welded or laser fused stainless steel beams (extruded) as follows:
Qty 28 beams W8 x 67# x 8000 mm long in SA 479 tp 304
Qty. 147 beams W8 x 67# x 6000 mm long in SA 479 tp 304
I found Amerex Products, but they are no longer producing. I also have a lead on Thyssen Krupp in Germany, but this may be at the cusp of their limitations.
Would appreciate the help.
RE: Looking for a Stainless Steel W8 x 67# Beam Supplier
www.aisc.org
or contact them. They provide info about availability of standard steel shapes. I've never seen stainless listed there but they might be able to give you a lead.
There's also the Specialty Steel Institute of North America
www.ssina.com
http://www.stainless-structurals.com/
As I recall, the prices are quite high - we ended up fabricating some 10" beams ourselves (small bridge crane girders)
Good Luck
Still looking!
Thanks!
