Controllogix Redundancy
Working with 1765-L62's and SRM modules using F/w 16.53
Can any tell me is there is a programatic was to force a slave (thats is DISQ) to do the following :
Step1) WIPE Current Program
Step2) Clear all Major Faults
Step3) Initiate Crossload from PRIM PLC
Step4) Initiate Sync & Sync
This would be exatly the same as plugging a brand new CPU into the rack as a secondary and powering it up. As a new CPU would then crossload from the PRIM.
Also is there any way of forcing a PLC to clear all fault remotly using CIP messages generated at another PLC?
