Biodiesel Separation (Oil Water Separator)
I would like to know:
- Biodiesel (B20, B10, B5) Surfactants could limit
Separator's (Oil and Water Separator)effectiveness?
- If yes then could you please tell me more about the
solution?
solution?
RE: Biodiesel Separation (Oil Water Separator)
Orenda
Methods that are used to break emulsions include lowering the pH, chemical additions, and heat. Some of these methods are more costly to operate than others. However, it is a common practice to lower the pH to around 5.3 units in order to break an emulsion.
You will need to conduct some bench top scale lab experiments in order to determine the best emulsion breaking technique.
Hope this give you soem clue.
David (Watson Process Systems)
