Measure the radius of a curve?
Is there a way to measure the radius of a curve?
I have a curve made using insert curve from XYZ points. The points were generated using a MicroScribe MX digitizer.
I realize that a curve may or may not be part of a circle, but can a segment be measured or take an average.....or something?
Also, can anyone guide me to some reference material on ways to use the digitizer with SolidWorks.
Steve
SW 2006 sp5.0
Steve
SW 2006 sp5.0
RE: Measure the radius of a curve?
You may be able to obtain approx radii by sketching over sections of the 'curve' with a true radius and then measuring that.
I have never used a digitizer with SW.
