DXF solid problem
DXF solid problem
We develop a graphical application able to produced different output file (PDF, EMF, WMF and DXF). We have a problem with DXF SOLID entities. For exemple if we have two rectangles one over the other one (making a big plus) I would like the edge of the rectangle under to be hide from the rectangle over has if it was fill with white color.
If I used SOLID entities with color 18 (black), everything appear OK in the model view, but in the layout view the Rectangle over appear in black.
Is someone can help me and please excuse my english.
mlu
mlu
RE: DXF solid problem
A) what I would like to have and what I have on model view
B) what I have on layout view and on printer
No, I don't know how to draw in ACAD 3D. The graphic made by our application is in 2D, so the DXF object are in 2D.
If you think that you can show me something in 3D that it will help me, I'm ready to listen your solution.
Thank you.
In the View Pull Down Menu>3D Views> SW Isometric or any other selection; this will create a 3D environment with the three axis shown; experiment.
In the Draw Pull Down Menu> Solids> Extrude; this will take a 2D shape in the X-Y plane and create an elevation in the Z axis; take any 2D shape and make it a solid with this command.
In the Modify Pull Down Menu> Solid editing> Union, Subtract, Intersect.....;Union will take 3D
objects in contact with each other and create a new solid;Subtract will take object with each other and depending of the selection method will create a new object with deleted features; Intersect will take objects in contact with each other and create a new object which has a form common to the objects in contact only;.... the rest of the commands you'll have to play with them but they are relatively easy to learn.
Good Luck
