Configuration / Linear Pattern
I have a rectangle block where I am putting in six holes. I used the linear pattern to add the six holes. Now I want to make a three hole version exactly half the size. Is it possible to specify the configuration on which patterned holes to suppress? I am using SW2008.
RE: Configuration / Linear Pattern
Now each pattern will have independent quantities.
Flores
Would you explain that statement, please?
-handleman, CSWP (The new, easy test)
So right now I have
1. A sketch of the rectangle which is extruded
2. A sketch of the hole which is the linear pattern.
In the feature manager design tree (FMDT) I see sketch but not the pattern. I double click on the sketch but it only opens it for editing. I then can Right Click on one of the circles and see "Pattern0". To make life easier, I have uploaded this simple-yet-doing-my-head in part.
Flores
