Pump energy at different fluid temperatures
I am trying to figure out the relationship between temperature of the pumped fluid and the amount of power the pump uses. I know that when the temperature is lower the kin vicosity will be higher which will make pumping harder, but is there any sort of table that shows this or formula i can use to figure something out? even a ballpark figure would be fine.
thanks.
thanks.
RE: Pump energy at different fluid temperatures
If you're near or over that, see http://www.mcnallyinstitute.com/14-html/14-04.htm
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
