How to generate a Tiff Image with alpha layer ?
I would like to generate a tiff image without background. Then I will open this file with photoshop to trim around the model. To do this, the file must be generated with an alpha layer. Is it possible with UG Photo ?
Thanks in advance
Didier
Thanks in advance
Didier
RE: How to generate a Tiff Image with alpha layer ?
You'll need a good image editor like Photoshop to work with you images in this manner but it sounds like you may be into that sort of thing already.
The other way of course is to bring a background into NX as tiff file before you render the part file. It is to be found under Raster Image in the menus.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
