ac2000 to ac14
ac2000 to ac14
ac2000 to ac14
There´s in the NET a soft that convert a DWG file of AC2000 to AC14?
RE: ac2000 to ac14
Autocad 2000 can save a drawing directly to a release 14 format using the saveas function in the file menu.
RE: ac2000 to ac14
I had written a VBA macro to batch convert all dwgs in a directory to ACAD14. opening and saving automatically.
I had sent a copy to Shadow. Maybe he can send you a copy.
If the need be great, I may find it somewhere among my old files.
www.homescript.com
RE: ac2000 to ac14
You might check out the download at www.thedraftingshop.com
-it's supposed to be able to do this.
Carl
RE: ac2000 to ac14
There's several shareware programs that convert any dwg (autocad2000 or otherwise) to DXF that can then be opened by R14 or whatever (then saved as R14). Very useful since it does so outside of autocad- no need to have 2000, no need to try to get a 2000 dwg 'saveas' an R14. One's called 'DWG2DXF.zip', there are others, try
http://www.cadalog.com/index.php
