Steel bulb tees
Steel bulb tees
Does anyone know where I can find the section properties for a W178 bulb tee? It is being used to support a gypsum roof system.
Thanks!
Thanks!
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Steel bulb tees
RE: Steel bulb tees
000
000
0
0
0
0
00000000000
Something like that.
RE: Steel bulb tees
RE: Steel bulb tees
Mike McCann
MMC Engineering
RE: Steel bulb tees
RE: Steel bulb tees
The only dimension I have is the height, so I am unable to calculate the section properties.
RE: Steel bulb tees
http
RE: Steel bulb tees
Below is a link to a site contains info on "Bulb Tees". However, it uses different dsignation system as compared to yours. Wish this helps as a lead in further look into this matter.
htt
RE: Steel bulb tees
First hit on google search
http://w
RE: Steel bulb tees
Kelowna, that is not quite the shape that I'm referring to. Check out the link posted by kslee and that will get you on the right track, although the flange is not tapered on the inside face and the "bulb" end is pretty square; not like a flange.
RE: Steel bulb tees
RE: Steel bulb tees
