MATH FORMULA FOR CALCULATING I AND K VALUES ON CNC LATHE
I NEED TO KNOW THE FORMULA FOR G02 AND G03 CALCULATIONS, INCLUDING I AND K VALUES ON A CNC LATHE.
                                           THANKS!
RE: MATH FORMULA FOR CALCULATING I AND K VALUES ON CNC LATHE
I do not know what your example is but I&K are simply the centre of the arc you wish to turn as an incremental position from the start point of the arc (the relationship depends on the machine you use).They can be as simple as the radius or you may need to work them out by trig.
i need to know the answer to 20 to the 300 power its a big number ya and calculaters dont go up that high.
2.037035976334486086268445688409EE390
Try drawing it in CAD.
