Composite Positional Tolerancing & Simultaneous Requirement RFS
I have a part I'm checking that has 2 distinct patterns of holes, a set of 6 counterbored holes and a set of 2 threaded holes.
Both sets of holes use composite position with the same datum features (faces so RFS).
Am I correct in thinking that the 'Simultaneous Requriement' only applies to the Pattern Locating Tolerance Framework (top line of FCF)?
I'm looking at ASME Y14.5M-1994 5.3.6 & 5.4 and don't see it explicitly listed but it's the only way it makes sense to me.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Composite Positional Tolerancing & Simultaneous Requirement RFS
Rather interesting. Are you checking it for functionality or merely for conformance to the Standard? Any chance of a sketch and what version? Is physical ident of the datum features enter into the equation?
I'm waiting to hear from the engineer wrt the functional requirement of the composite profile as it wasn't clear to me how the value was determined.
I don't think it's worth the effort of a sketch, and if you mean version of the standard it's in my OP, but thanks for the interest.
KENAT,
Don't know if this will help much, but when read 5.3.6, it does not require the patterns to be checked with the same setup, but allows that they may be.
Is the PLTZ rectangular or circular? (no direct bearing on your question)
If the two patterns are specified WRT the same DRF and at the same material condition then they are a pattern and must meet their requirements simultaneously. This means you can't check one set of features, then move the part in order to make the other set of features come into tolerance. Using the same set up is how this would be checked. Using different setups completely invalidates the simultaneous requirements of the part.
Powerhound, GDTP T-0419
Production Manager
Inventor 2009
Mastercam X3
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
With reference to Fig 5.17 of the 1994 Std, what would be the difference if simultaneous or separate requirement imposed??
KENAT,
The FRTZF would not.
I would base this position on 5..4.1 which states that the PLTZF and FLTZF may be verified separately. To me this allows the PLTZF callout along with other patterns and features to be checked in compliance with the simultaneous requirement rule, were the FLTZF would be another separate verification.
DesignBiz
DRF's are generally not unique, and not necessarily repeatable. Y14.5.1 explains this in terms of "candidate" DRF's that occur in cases where the datum features can shift relative to their simulators. Such cases include datum features referenced at MMC or LMC, and "rocking" datum features.
Figure 5.17 refers to FCF's that reference three planar datum features. If simultaneous requirements were imposed, then both FCF's would have to be checked in the same rocking position. If separate requirements were applied, then the datum features could be rocked differently for each FCF.
Evan Janeshewski
Axymetrix Quality Engineering Inc.
www.axymetrix.ca
For a minute without regards to the Standard, if the DRF is not repeatable to the extent necessary to very the controlled dimension and its respective tolerance, I think we have a problem.
For the sake of simplicity, let's consider fig. 5-18. As the example shows, the 2 hole patterns are separate requirements which means they don't necessarily have to be oriented as shown. The 2 large holes have to be oriented 180 degrees apart as do the 2 small holes but each hole pattern does not have to be oriented 90 degrees WRT each other. They are 2 separate 2 hole patterns with no relation to each other and not a pattern of 4 holes. If the SEP REQT were not there, then it would be considered a 4 hole pattern and all the holes would have to be oriented 90 degrees apart.
Production Manager
Inventor 2009
Mastercam X3
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
On the surface it is a fairly simple example and I understand what you have stated. However, I must ask that
if the hole patterns are not 90 degrees apart, just what is the allowable deviation. I thought we have a rule that covers 90 degree relationships of centerlines on drawings.
If orientation is of no concern, why introduce C?
One thing that concerns me as an example in the standard is that you really don't know which surf is A. It needs PHYSICAL IDENT.
Ringster,
RGHC Checker
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
Considering the PLTZF can be verified separately from the FLTZF, it would appear that PLTZF(s) would need to follow the simultaneous req rule in regard to other FCF's with the same DRF and material conditions.
DesignBiz
I believe that to ans your orig post, the answer would be that 'Simultaneous Requirements' does in fact apply only to the PLTZ.
As regards
You seem to forget paragraph 1.1.4 of the ASME Y14.5M-1994 standard.
KENAT,
