ultimate shear strenght of aisi 1070
What is the Ultimate shear strenght of AISI 1070 annealed to 102 Brinnell.
It is for know the pres force needed to cut it by a die .
Pardal
RE: ultimate shear strenght of aisi 1070
It has been found empirically the the maximum force to produce shearing, P(max), is given by
P(max) is approximately (0.7) X (ultimate tensile strength) X (sheet thickness) X (length of the sheared edge).
The ultimate tensile strength of your stock (at BHN 102) should be about 51,000 pounds per square inch.
thanks for it
Pardal
