Max. Working Temp. (MWT)
Hello all, I was wondering if anyone is familiar with the terms "maximum working temperature" and "upper design temperature"? They are stated in a spec I am reviewing and I never seen those terms used before. Any help would be greatly appreciated.
RE: Max. Working Temp. (MWT)
Maximum Working Temperature = Maximum Operating Temperature
Upper Design Temperature = Design Temperature (i.e. maximum temperature used in design per UG-20(a))
Lower Design Temperature = Minimum Design Metal Temperature (MDMT) per UG-20(b)
Or perhaps you were given several sets of design pressures and temperatures for the new vessel? In such a case the design pressure would likely be lower with each increase in temperature. The highest temperature would be the "maximum working temperature" of the sets.
Mike
when in doubt, ask the writer of the spec.
