tap problem
tap problem
tap problem
I have a large galvanized steel bucket and I want to tap the bottom side so the fluid in the bucket can be poured out via 1/2 inch pvc pipe.
I was hoping to get some advice on what would be the best/easiest way of doing this with standard parts?
RE: tap problem
Don't ruin the bucket.  When have you ever been able to sell a bucket with a hole in it?  Put a submersible pump in the bucket and run the PVC pipe over the lip.  Resale of the bucket will be at a much higher price.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
RE: tap problem
Valuable?  Well I can tell that you have not been across the Straits to the beginnings of the Sahara in Morocco. Its not so much for the bucket itself, but rather for what's not in the bucket.  If the bucket had water in it, instead of a hole, it could even save your life.  In Saudi Arabia, if you wanted to keep your bucket, the only way to do so was to keep your eyes on it, or ... make a hole in it.
RE: tap problem
Thanks jte. I think that a submersible pump is far more expensive than the bucket I have
RE: tap problem
dkm - Your'e welcome!
I hear you, BigInch... But methinks I would get the water in the bucket a bit salty as I swam with it across the Strait to the Sahara, thus reducing its life saving potential!
jt
RE: tap problem
Make a U-tube from the PVC pipe and start a siphon to drain the bucket.
Mike Halloran
Pembroke Pines, FL, USA
RE: tap problem
Pour the water into a funnel with a 1/2 inch PVC pipe attached. Then you get to keep the bucket without a hole.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
