punching shear of pile caps
Hi, when checking against punching shear at 1.5d zone (according to UK code), but at whatever distance your code states. How do you deal with overlapping zones, say you have 4 piles and all perimeters overlap?
RE: punching shear of pile caps
If you "heard" it on the internet, it's guilty until proven innocent. - DCS
http://www.eng-tips.com/supportus.cfm
It seems to me that if the zones overlap, you don't really have punching shear, but rather beam shear. With 4 piles, you would use the full pile cap width and effective depth. Check punching shear under the column.
The overlapping condition can be eliminated (for coupling piles) by adjust the pile spacing farther apart (note: the two cones are in opposite directions vertically). I wouldn't worry too much about overlap in this case, draw cone diagram with stresses along cone surfaces, you would know why.
However, your design is likely governed by one way action, treating the pile cap as rigid beam, supported by structures above, with concentrated loads from piles, and soil reaction.
Strut-tie method is strongly recommended for this case.
