Padeye Welding Procedure
I have a skid that I am trying to weld padeyes on, and I am looking for some references to find the proper welding procedure. Any ideas would be helpful.
RE: Padeye Welding Procedure
The first order of business is to know the materials of construction. Once you know this information, further information can be provided.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
I am definitely not an engineer but should you not have some form of compensating plate for the padeyes to weld on to.?
BB
Be more flexible for the rigging crew, and the padeye strenth/load is carried by the certified metal (not welded) and their nuts/washers.
In the US the following may help guide you:
ASME BTH-1-2008 Design of Below the Hook Lifting Devices, Chapter 3
ASME B30.20a-2003 Structual and Mechanical Lifting devices. Section 20-1.2.2 Construction
CMAA crane requirements
AASHO 1.6.17
Steel Construction Manual-AISC
Occupational Safety and Health Administration (OSHA) 29 CFR standard 1926.753(e)(2) and 1926.251
American Society of Testing and Materials Specifications A391
Naval Facility Command NAVFAC-307
American National Standards Institute, "Below The Hook Lifting Devices"
