Linear Slide Joystick
I am trying to give an operator a control for moving a 25' slide. In a past application I used an analog joystick with a frequency drive. It works ok, and once the operator gets used to the deceleration and response they can usually get close. For another application with a 36" stroke I built a 12" linear joystick out of a linear slide and a linear transducer. It is a 3 to 1 ratio (move the slider 1" get 3" of stroke) and it enables the operator to move the slide to different positions very quickly and still make the small moves accurately. I am afraid if I use a 12" linear joystick on a 25' slide the small moves will be difficult. I was considering a device like a trackball that would allow them to make small moves easily, and large moves very quickly. I don't know if it would be any better than the joystick. Does anyone have any suggestions?
In case you want to know there is a linear slide positioned above a log (tree) and they are going to mark the beginning, end and defects with a laser line mounted on the slide.
RE: Linear Slide Joystick
Please note this is not tried and tested.
Hope this helps
Let me know what you come up with.
Anton
