Cummins Diesel Generator
Guys,
Does anyone out there happen to have a resistance/temperature curve for a Cummins engine temperature transducer?
I also need a resistance/pressure curve for oil pressure.
Cummins are not being helpful and we have no accurate testing equipment on site to make the measurements ourselves.
Any help gratefully received....
RE: Cummins Diesel Generator
If it is broken, fix it. If it isn't broken, I'll soon fix that.
Bill
"Why not the best?"
Jimmy Carter
The transducers are not broken, we are changing the control system that utilises the analogue inputs for control purposes.
The guys "on site" unfortunately don't have the correct equipment to actually "map" the correct resistance/temp/pressure curves.
Information from a colleague that has come to light today, is that the transducers are not accurate enough for how we are using them (temperature based kW control of the engine), so the quickest and best solution was to exchange them for known 4-20mA output units.
Problem now solved, thank you all for the input, good advice is always appreciated.
Cheers,
Ian
Bill
"Why not the best?"
Jimmy Carter
