CAN/CSA-S16-01 14.3.4
Af is flange area in this code, does it include compression and tension flange?
I can't find more commentary for it and the similar formula,Af is compression flange area in AISC 89. So I want to make sure I didn't misunderstand.
Thank you.
Thank you.
RE: CAN/CSA-S16-01 14.3.4
S16 is steel design code. I had no idea for S06
